FS: 2x Rockford T1500-1bd Power - $400 each OBO
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
These come with boxes and paperwork... no remotes.
Number of Channels 1
Rated Power
continuous power
500W x 1 @ 4-Ohms RMS
1000W x 1 @ 2-Ohms RMS
1500W x 1 @ 1-Ohm RMS
Total Power
total sum of 'rated power' 1500 Watts
Bridgeable No
Efficiency (average) 86% @ 4-Ohm
85% @ 2-Ohm
68% @ 1-Ohm
Crossover Controls Low-Pass (LP): 35-250Hz 24dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Infrasonic Filter: -3dB @ 28Hz 12dB/Octave
Signal Input Low level: 1 RCA pair
Signal Output Low Level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch Bass EQ
(overrides built-in Punch Bass EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class bd
Frequency Response 20Hz to 250kHz +/- 0.5dB
Shipping Weight 14.35 Lbs.
(6.50 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
Rated Power
continuous power
Total Power
Bridgeable No
85% @ 2-Ohm
68% @ 1-Ohm
Cooling Convection
Thermal
Protect
(6.50 Kg.)
