Sold Blown Soundstream Pca2000d
dadon
Guys I have a blown ss pca2000d amp, that has blown mosfets. Looking to get rid of it as I have no time or money to fix. No internal pictures.. just pictures of the shell. Its missing the cheap spider plastic design piece.. other then that its in fair condition. Asking 80 bucks shipped. Just looking to move it out! It won't cost more then 130 to repair even if you pay someone reasonable to do it!
Power:
1100 Watts x 1 Channel @ 4 Ohms
1500 Watts x 1 Channel @ 2 Ohms
2000 Watts x 1 Channel @ 1 Ohm
4000 Watts Peak
Min. Impedance Unbridged: 1 Ohm
Not Bridgeable
TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
High Quality FR-4 Circuit Board
Class D Circuitry
Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
Variable Subwoofer Equalizer: 0 - 18 dB
Phase Control: 0° / 180°
Frequency Response: 5 - 250 Hz
Adjustable Input Sensitivity: 0.5 - 4V
Damping Factor: >200
Fully Regulated MOSFET Power Supply
PWM Circuitry
Platinum Power and Ground Connectors
Accepts up to 16VDC Power Input
Wire Bass Remote Included
THD @ Rated RMS Power: 0.5%
Low Frequency response: 5 Hz
High Frequency Response: 250 Hz
Speaker Level Inputs: No
Amp Preamp Outputs: 1 Pair
Built-in Crossover: LP (50 - 150 Hz), Subsonic (15 - 40 Hz)
Bass Boost: 0 - 18 dB
Signal-to-Noise Ratio: 80 dB
Dimensions: 18" L x 9-1/2" W x 2-1/2" H
the amp is in storage.. somebody will buy it without internal pics. I fix amps so I know whats wrong with the amp. If it doesn't sell ill just keep it and fix and resale for more. Not a big deal.
dadon
dadon
missouri
dadon
