Sold FS: 2 MTX 225HO's
if you dont know what the specs are you dont want them //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
they are probably the second best cheater amp out there.
MTX rates them at only like 650-700 watts @ 1 ohm.. but they actually hit close to 1000 watts at 1 ohm. (from testing)
rated at 25x2 watts.
Thunder225HO Amplifier
Low impedance, High-Output amplifier.
Individual gain controls for left and right.
2 sets of RCA connectors.
RMS Power measured at 12.5 Volts DC:
25 Watts x 2 into a 4 Ohm load with less than 0.05% Thd+N
50 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
100 Watts x 2 into a 1 Ohm load with less than 0.3% Thd+N
200 Watts x 2 into a 1/2 Ohm load with less than 0.5% Thd+N
400 Watts bridged into a 1 Ohm load with less than 0.5% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
65 Watts x 2 into a 4 Ohm load
120 Watts x 2 into a 2 Ohm load
200 Watts x 2 into a 1 Ohm load
370 Watts x 2 into a 1/2 Ohm load
700 Watts bridged into a 1 Ohm load
Signal to Noise Ratio:
> or =110dB A-Weighted
Damping Factor:
> 200
Frequency Response:
20Hz-20kHz ± 0.25dB
Dimensions:
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm) Including IsoFeet™
Also Available: Thunder225HO with high gloss white finish
Jason84
Jason84
Green Bay
TooLowTooGo
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
