FS: 2- Db Drive Okur 7500.1's
solo1
Memphis
With the pair strapped I got 24k with a 14v drop and .7 ohm imp. rise/ 13k with a 10.5 v drop and 1.0 ohm imp. rise. Only used for comps, never street played or abused.
Physical 9 of 10 and mechanical 10 of 10
$1400 Shipped. One left.
NO TRADES!!
RATED POWER 14.4 VOLTS: 1 X 6500 WATTS @ 1 OHMS
RATED POWER 14.4 VOLTS: 1 X 4000 WATTS @ 2 OHMS
RATED POWER 14.4 VOLTS: 1 X 2000 WATTS @ 4 OHMS
Frequency Response: 20Hz ~ 250Hz
Signal to Noise Ratio: 100dB
Damping Factor: 250
Efficiency @ 4ohm: 85%
Low Level Input: 6V - 0.2mV
Low Pass Filter (@ 24dB Slope): Variable 35-250Hz
Bass Boost @ 45Hz: Variable 0-9dB
Subsonic Filter (@ 24dB Slope): Variable 10-50Hz
Phase Shift: Variable 0-180 degree
Master/Slave (Linkable): Yes
Remote Level Control: Yes
RCA Line Output: Yes
Working Voltage: 8.5 - 18 Volts
Alright guys $1300 Shipped, thats as low as its gonna get!! Last chance to get it before it goes on ebay,so if you have any interest LMK.
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
912
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
solo1
solo1
Memphis
Bettr n' Revrse
    May 22, 2024
    May 22, 2024
