FS: 2- Db Drive Okur 7500.1's
solo1
With the pair strapped I got 24k with a 14v drop and .7 ohm imp. rise/ 13k with a 10.5 v drop and 1.0 ohm imp. rise. Only used for comps, never street played or abused.
Physical 9 of 10 and mechanical 10 of 10
$1400 Shipped. One left.
NO TRADES!!
RATED POWER 14.4 VOLTS: 1 X 6500 WATTS @ 1 OHMS
RATED POWER 14.4 VOLTS: 1 X 4000 WATTS @ 2 OHMS
RATED POWER 14.4 VOLTS: 1 X 2000 WATTS @ 4 OHMS
Frequency Response: 20Hz ~ 250Hz
Signal to Noise Ratio: 100dB
Damping Factor: 250
Efficiency @ 4ohm: 85%
Low Level Input: 6V - 0.2mV
Low Pass Filter (@ 24dB Slope): Variable 35-250Hz
Bass Boost @ 45Hz: Variable 0-9dB
Subsonic Filter (@ 24dB Slope): Variable 10-50Hz
Phase Shift: Variable 0-180 degree
Master/Slave (Linkable): Yes
Remote Level Control: Yes
RCA Line Output: Yes
Working Voltage: 8.5 - 18 Volts
solo1
solo1
Memphis
Bettr n' Revrse
