Sold FS: 12 15" DC audio lvl2s
JL Audio
ThugStep
Rating: 94.4%
17 1 0
I have 12 of them, looking to get around 125 + pp fees per woofer.
I have no pics as I literally just got them in at my grandparents and that a good hr drive I have no intention of doing just for pictures. I have a 2 door celica hatch so I couldn't haul them all back in one trip either.
only pics I have are from the previous owner:
looks like i'll be doing some 8s or 10s instead so these are not needed now.
let's get some interest in them, looking to sell multiples at a time but I am willing to do singles if there is a lack on interest.
Quoted from dcsoundlab.com
The Level 2 is one of our greatest accomplishments. It’s a sub that has everything you need in a daily driver except the cost.
The Level 2 starts out with a double-stacked FEA optimized motor wrapped in a magnet boot with a chrome top plate and
T yoke to keep it looking good
It has 18 mm of X-Max, progressive spider, 2.5" voice coil,
cast basket, push terminals and a under rated suggestion of 300w RMS / 600w peak power handling.
This sub works great in sealed or ported enclosures and defiantly gives you more bang for your buck!
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8” OD flat linear roll spider
• Heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly - Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 4 ohm 2.5” Hi-temp Aluminum voice coil wound on black
anodized voice coil former
• Rubber magnet cover
AS FAR AS TRADES: would trade to a smaller vehicle automatic, gf needs one. Also would trade for sundown 3000s/sundown 1500s ( both/either but be newest model ), ascendant audio chaos 10s, sundown E8s, etc.
You have join bones and I in the "I can't make up my mind" club
WELCOME
I bet you money I have had more systems in my rides than either of you put together haha.. all mine were just parts and pieces though.. so they don't count //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
:eek:.. just decided it may be nicer to go with some sundown overall. 32 8s or 10s *cough*
EDIT: also, you have a pm for your tracking on the stetsom 4 channel
dude I had my first system when you were jsut starting to eat gerber baby food with a spoon. it was straight up dual post cass. with a coustic 180 4 ch bridged to 1 coustic 8 in a plywood box with 50 1/2inch holes drilled in it (port:eek:)
So just back th ^&%$# off.
as for the 32 10's, great idea;)
id love to see 32 10s in a celica i think you said you had.
me too but there isn't any room for that, now apart from the attempt at trying to make me sound retarded.. i'll be buying a van sometime down the road, was the same reason I had 12 15s...which were going to be 24 in the end.
at current time, I have the celica..which has no system in it.
mounting depth?
here is what the site says:
15"
Mounting Depth
7.5"
Mounting Hole Diameter
14"
Motor Width
6.5"
Weight
19.5lbs
VC Diameter
2.5"
Magnet Weight
15lbs
Power Handling RMS/Peak
300/600
Impedance
D 4ohm
Sd
872.00cm²
Vas
145.10 L
Cms
1.36e-04 m/N
Mms
168.60 g
Fs
33.2 Hz
Bl
20.89
Re
7.20 ohm
Qms
7.88
Qes
0.58
Xmax
18 mm
Sensitivity
91.5 dB
Suggested Sealed
1.5³ - 2³ ft
Suggested Ported
2.5³ ft
Suggested SPL Ported
3 ³ ft
JL Audio
ThugStep
JL Audio
KY
Twisted_0912
