Frustrated!!!!
If you just spent 500 bucks upgrading to a more powerful setup and the new sub bottoms out when the old,cheaper, inferior one didn't, i bet you would be upset too. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
And this isn't meant to be a duplicate of my thread, this is to see if maybe i have the same problem with mine as the threadstarter did with his, and if there is any way to test it.
ok then. I would expect a moderator on their board to be more helpful. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Watch your mouth boy. Your going to fuk yourself out of any help that you could possibly get by insulting him.
I dont have any experience with ED amps and Im too lazy to read through the thread again to see what you said about ur gains. How are they adjusted? Bass boost is no more than 1/4 up? Xover not past 1/2 way up or more than ~100hz? Ground is clean and tight?
Bass Boost is completely off, i don't like it on, it makes it boomy sounding. Gain is about 1/2, crossover is at around 80. Ground is fine, bolted onto my fender.
f150_on_32s
f150_on_32s
Thibodaux, La
ls1pimp
