Vecticus
Dubstepper
So I wanted to make sure I wasn't clipping my front stage so I did the research and after some math (thanks Ionakron) to see how much ac volts each bridged channel at 4ohms had to be, it came out to a little over 26. something volts. I flattened out all my settings, made sure bass boost and cross overs were set to zero and inserted a 20 minute Pink noise CD. I turned my HU to exactly 3/4 max volume (26 out of 35) and turned my gain all the way down. Multimeter showed 0.3 ac volts. I turned it halfway and it showed 5. something volts......I started thinking... I'm not even half way to the 26 volt mark and this amp is turned up half way. So i just maxed it out. Multimeter shows 11.5 volts maxed out. This amp bridged supposedly does 180 watts rms. The CDT HD 61's are rated at 170 or 175 watts rms. I'm stumped, aggrivated, and just ready to trash it all. Could definitely use some help.
