Front Speaker Help. no amp
Jam1e
Hi, I have a 95 del sol si and im looking to get new speakers front and rear. I have a Kenwood deck. I will not be powering these with an amp. i would like to have great sound quality and some bass if possible w/out an amp. My budget is 100 max for fronts and 100 for rear
Thanks
Jamie
If you're still looking, just get front comps and an amp. You should have no problem scoring both in your budget range that you were planning to spend on front and rear speakers together.
You have a Del Sol, so there's little (or, more importantly, no) point in having any rear fill with such a small interior space.
If u had a alpine deck you could get one of those ktp-455 plug and play amps and then get some descent coaxials or comps and have descent midbass. But u don't so what are your factory speaker sizes and we will see what you could get.
Del Sol has 6.5" in the doors. Lots of options for the OP to choose from.
Installed a set of Kicker DS650's this past weekend in an Impala. Very impressive for a low wattage driver. When I first put them in I thought I had hooked the 6x9s up as well with the amount of output they presented.
Hi, I have a 95 del sol si and im looking to get new speakers front and rear. I have a Kenwood deck. I will not be powering these with an amp. i would like to have great sound quality and some bass if possible w/out an amp. My budget is 100 max for fronts and 100 for rearThanks
Jamie
dude your car's cabin is like 3 cubic ft why wouldn't you just run a nice small 2 channel to a good set of comp in the doors. probably cheaper that what you're looking to do and definitely sound way better
Jam1e
Jam1e
Green Bay
Jam1e
