2 15" l7 ARE EQUIVELENT TO 2 18" SUBS BASED ON CONE AREA SO i FIND THAT VERY HARD TO BELIEVEI'm also curious about the subject, or as a general principal. Local guy hooked up his 4 12" JBL 12W3s (not sure about box) and compared 2 15" L7s in 3'^3 ported at about 34Hz each, both on 1kW, and he claims that the JBLs were better. The only variation on the test was that when testing the L7s, he had an alternator problem and was running on 11V, so a drastic decrease in power, he was not convinced that the output would decrease by that much. Just my 2c from what I've compared.
I would go with 4 15"s. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
wat?1 15" l7 ARE EQUIVELENT TO 2 18" SUBS BASED ON CONE AREA SO i FIND THAT VERY HARD TO BELIEVE
i edited it it was suppoesd to say what it says now. my bad not enough coffee yet lolz.//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
You must be using some kind of Pythagorean Mathmatics that I'm unaware of. Possibly even some sort of Torsion Physics model...yes?
not really wantin a rattle i want deep loud bassLike I mentioned before go with the 2 15" Nightshades & 2 saz3500's it will give you that gangster rattle & you will be louder than the rest of your homies, just build the correct box.
How much does it usually cost to have a trunk rhino lined?with that kind of output it will still rattle dynamat is way over rated IMHO i have seen as much as 3-4 db gain using it but it isnt cost effective IMO I have also seen no gain whatsoever with it.if you really want to eliminate as much rattle as possible take everything out of the trunk including wires and lights and go have it rhino lined. its a little cheaper and works as well or better I think.
how do you figure this?depending on the subs 2 15" subs in an ideal enclosure will be louder and have better sq than 4 12" subs will.the key is comparing apples to apples same brand model ect., in a situation like that the 2 15" would always be my choice vs 4 12".
