renier
Vivo BOoOM .i.(0_o).i.
i've choose this amp for driving my L7S15 dual 4 @ 2ohms..
Detail
1x600W RMS at 4 Ohms
1x1800W RMS at 2 Ohms
1x3600W MAX at 1.3 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stereo Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Variable Low pass Filter (50Hz~150Hz,24dB/Octave)
Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
Phase Control 0-180 Degree
Remote Bass Level Control
Input Impedance:10K Ohms
Soft Turn-on/Turn-off
Side Leg Mounting
Red Lighting Illumination
THD:
S/N Ratio: >90dB
Input Sensitivity : 200mV ~8V
Freq. Response : 15Hz ~ 150KHz
Patent Pending
Heavy Duty Power Coated Heatsink
Dimensions : 8.6''(W) x 2.74''(H) x 15''(L)
it's a pyle amp..can i trust this amp?
will the sub show its real power?
the ported 8cu.ft box its not finished yet..my previous box,a 6cu.ft(w/obraces inside)can't hold my sub..
i'm happy with the results, but i want to ask you if i made the right choice or not..
my previous amp was:
lanzar
2x600W RMS at 4 OHMS 2x1200W Max at 4 OHMS
1x2400W Max at 4 OHMS Bridged 2x1000W RMS at 2 OHMS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Gold RCA Inputs
Line Outs for Left and Right Channel
Low Pass Filter Controls
High Pass Filter Controls
Power and Protection LED Indicators
THD:
S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 10Hz~35KHz
Subwoofer Remote Level Control
Dimensions: 9.82''(W) x 2.34''(H) x 20.47''(L)
any comments and suggestions?
Detail
1 Ohm Stereo Stable
MOSFET Power Supply
Side Leg Mounting
THD:
S/N Ratio: >90dB
Patent Pending
lanzar
Bass Boost Circuit
2 Ohm Stereo Stable
Gold RCA Inputs
THD:
S/N Ratio: >90dB
