How much current will 2 2500d/5000s pull
My box will go from wheel well to wheel well and i'm branching a battery rack off the side where I can fit a couple HC2400s or 4-5 HC800s. Most likely, I'm going to try running my XX Colossus II off 3 HC800s and a yellow top under the hood. You'll need nearly twice what I have, so what Mike said is right. 6-7 Yellow top caliber batts. You could always try the HC1400s, get 4 back there and put an HC2000 or HC2400 under your hood if you can fit it and you should be fine for daily.
i might not be able to do those amps then, im only going to put a 300a alt and 1 2150 or hc2400 probably, i dont know what i can fit up front, its a big everstart maxx there now, and the blue top in the back
what are some other more efficient amps that do ~ 2500 ish @.7
or is 1 big amp better?
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
bamaboy
