Former broke thru the cone
Im tuning the next box lower. I like the high 20s to much to be tuned in the mid 30s. It let go on Rack city
I don't understand why people think they need to tune so low. 32 is the absolute lowest you should EVER have to tune if you are properly designing your ported box.
---------- Post added at 11:35 AM ---------- Previous post was at 11:34 AM ----------
It's either CA glue or goop I don't remember...I think it's CA glue
Either will work. CA glue is what is regularly used, Goop is for emergencies.
Simple... I'm not going to make it to many SPL events this season so I might as well build a air mover
Wow, DC must be using the same factory as Audioque to build their softparts. Inadequate or poor quality glue on the tripple joint. As you see that's not broken cone, that's broken tripple joint.
This is what a broken cone looks like:
You may be able to shim up the coil and use a shitload of thick CA glue to put that back together, but odds are without a cone attatched you probably beat up the bottom of the coil pretty good.
I'm just going to send it in. I'm going out of town for a few weeks so I won't miss it
LosIsATool
LosIsATool
Pensacola, Florida
SPLaudio
