Forgot I had these subs in the attic, what box?
Jroo
Wife had me cleaning up the attic and found an old box. I forgot I bought a set of credence clearance subs couple of years back cheap. Credence gave some very general box requirements and specs. Said could go in 0.5 sealed or 1 cube ported, but didnt giving tuning or port size. Looking at the specs, do either of these make sense or would you do something different? I will do a something quick as a project with my 9 year old duing his winter break coming up.
here are the specs Credence gave for the 2 10" subs I have:
Power Rating RMS Cont. 250 Watts
Max Power Rating-Unclipped Amp 350 Watts
Freq Response 25-150 Hz
Nominal Imp 8 Ohms
Voice Coil 2" 4 Layer
FS 25.18 Hz
Qms 8.8040
Qes 0.3579
Qts 0.3439
Vas 67.30 Liters
Cms 0.3994E-03 M/N
Re 6.93Ohms
BL 17.505 Newtons/Amp
Sd 0.034636 Sq. m.
Mms 0.100017 Kg
Hvc 0.980"
Hag 0.375"
Xmax 0.303"
Xlin 0.605"
Ref Eff 0.2885%
Predicted Output 86.802 DB/1W/1M
Nominal Imp 8 Ohms
FS 25.18 Hz
Qms 8.8040
Qes 0.3579
Qts 0.3439
Vas 67.30 Liters
Cms 0.3994E-03 M/N
Re 6.93Ohms
Sd 0.034636 Sq. m.
Mms 0.100017 Kg
Hvc 0.980"
Hag 0.375"
Xmax 0.303"
Xlin 0.605"
Ref Eff 0.2885%
they are labeled as Bostwick HD pros. I have heard the same sub was labeled as an Atomic model and I think one other sub. They have been in the attic about 4 years, couldnt tell you how old the sub actually is. I think credence had the either laying around or had parts and built them. I Also have a JL 18w6 from them and I think it was parts they had left as they were a JL build house. They built a bunch but could not put the JL logo on the dust cap.
Well, i wouldnt make a closed enclosure.. I think i would do a vented box..
If you do the vented, it would be 39,7L, and two vents with the size og 0.047m in diameter (4.7cm), and a length of 26cm each, im sorry it isnt in inches, and ft3..
This is without me ever listening to the sub, but i plugged it into WinISD, and thats the best i could get out of it..
You could maybe do a 76litres box, with two vents with the size 0,0047m diameter, and 0,181m length.. You will lose a Little overall dB, but it goes a Little deeper..
Theese numbers are 100% taken from WinISD, where i tried some diffrents numbers.. Theese where the one i liked the look of..
Well, i wouldnt make a closed enclosure.. I think i would do a vented box..If you do the vented, it would be 39,7L, and two vents with the size og 0.047m in diameter (4.7cm), and a length of 26cm each, im sorry it isnt in inches, and ft3..
Thanks for modeling, sounds like you modeled sealed and ported? Can you tell me what sealed sizes and responses it came up with?
I actually did both Sealed, ported, and 6th order bandpass.. I prefered the look from the portet..
Ported 1: Tuned to around 30hz -3dB.
Ported 2: Tuned to around 24hz -3dB, but with a +1.5dB gain from 70hzish
Sealed: Tuned to around 50hz -3dB, 30hz is -10dB.. 21Litres net.
6th: This one is kinda funny.. It's tuned to around 23hz, but with +/- 1dB, and all in all there is a Little output with this box.. If we take it from the lowest beside 23hz, and take -3dB from that it's tuned to 20hz, but than u will have -2dB with 1watt.. at 28hz, u will have -1dB with 1 watt..
Front chamber: 10L, 2 ports which is 0.047m*0.249m
Rear chamber: 55L, 2 ports which is 0.047m*0.430m
I would either do ported 2, or 6th order.. :)
Jroo
Jroo
richmond virginia
whazz
