ford ranger ext. cab build...
  • 4
RangerDangerV2
st cloud MN
the build for the atomic is on hold for now... so lately i have been lacking in the bass department. Here's what goin in the ranger-
4 sundown sa-8's in 4.03 cu. ft. net volume- tuned to 29 hz
2 xs d3100's
dc power 185 amp alt
AQ 2200 D
1 run of 0 ga. xp flex power and ground
hoepfully it will get loud and low, probably will start on the box sometime this week...
well plans changed a little... I went with an atomic 3k and a dc power 250 amp alt... the box is 5.75 cu ft gross and 3.5 cu ft after displacements, which gives me .7 cu ft for each sa8. The box is tuned to 31hz.
bumpin101
bumpin101
bumpin101
687
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
RangerDangerV2
RangerDangerV2
st cloud MN
JerryEllis
    May 20, 2024
    May 20, 2024
