no i dont. ill tell you how i think wireing goes just from observation no one ever really told me how it goes.have you drawn up a layout plan?If not you need to.
haha welll i have absolutly no idea how to groundDraw it out I can't express that enough, that way you can make a check list to make sure you don't leave anything out....
yeah you got it for the most part. You could run the ground from the amps to the frame of the truck instead of all the way back to the battery...
and don't forget the REM's from the amps to the HU.
make sure the amps are fused properly at the battery.
It's not difficult imo.
yeah subs is going to be in the back right seat and i think im giong to attach the amps to the sub box unless thats a bad ideaoh geezIt's not hard.
Do you have an idea of where your going to mount the amps and subs?
uhhh yeah i probably can i think im might have an idea ill make a drawling latercool. do you have space to fit both amps under the left side seat?
I'm not a big fan of mounting the amps on the sub box unless its the only option.
no i dont think so theres enough room im prety sure. if it doesnt fit there then i can put it behind the seat back if all else failsthats a great spot, especially if you can keep your amps unseen/stealth.Do you have to leave the seat out if you build a amp rack there?
read this if you haven't already. get a heads up on what you will be dealing with.
