Ford F-150 Extended cab
Jensen........ *shudders*
Anyways, their website says .75 cuft per sub for Good bass performance, 1.0 cuft for Better bass performance, and 1.25 for Best bass performance. So anywhere from 4 to 5 cuft total would be good.
And thats for a sealed box, btw.
Originally posted by kbjt jensen sub's are loud clear and i don't know way people say thay **** there just as good as anthing!!!!
they are as good as anything by pyle, pyramid, legacy, lanzar. you think they are as good as anything i'll put a pair of RF He2's against 4 jensen 12"s.
adam
I have a ford ranger xlt extended cap i use 2 small sealed boxes placed behind the seats of 1.15 cu. ft. each for 2 sub kicker cvr12dc with a rockford (500s.2) and the bass sound is amazing, maybe you can do 1 box(2.00 to 2.5 cu ft)for 2 or like me 2 small 2 small boxes(1.00 to 1.25 cu. ft. each)
Using sealed boxes is better for you because works good on smaller places but you need more power than vented boxes, in vented boxes use less power but you will need 2 cu ft for each woofer that means 4 cu ft total (a lot of space and bigger boxes).
Good luck with your projet!!!
Chelo
Puerto Rico
Just so you know....Your fighting a losing battle here. "just as good as anything?) Apparantly you haven't heard anything besides jensens otherwise I'm sure you wouldn't have made this comment:banghead:
i have 2 rockford 12'' sub's and the jensen are a little quiter but there still loud and who cares there just sub's get a life.......//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
all you need to do is box them right and i gus you don't know how to do that!!! and i know that there not the best sub's out there. There are alot beter ones out there.
Originally posted by kbjt all you need to do is box them right and i gus you don't know how to do that!!! and i know that there not the best sub's out there. There are alot beter ones out there.
I'm not going to argue with you over this (theres a place for that but not here). So I guess your right.....Jensen subs are awesome. I'm sure they go nicely with your pyramid amp and road gear head unit //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
my head unet is $220 my amp is $400 have you ever herd a jensen sub????//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Originally posted by kbjt my head unet is $220 my amp is $400 have you ever herd a jensen sub????//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I have heard jensen subs!!! I never said anything bad about them? I simply said they are not "just as good as anything"
Have you ever heard a XXX or orion hcca sub?
big time spender lol. price has nothing to do with it. i paid 500 for my h/u it retails at almost 1 grand your point? i paid 300 for my amp they used to sell for 1 grand new your point on price?? jensen's are decent at best RF's will blow them out of the water i know b/c i've installed many pairs of boths. we had a lot of idiots at best buy what can i say.
adam
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
730
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
kx100kicks
kx100kicks
Alberta, CANADA
bumpin_blazer
    May 24, 2024
    May 23, 2024
