Ford Explorer Sport Trac.... WTF?
starkfu
ford factory amplifier, however, this is one of the few factory systems that are in fact safe to turn on the amp, in fact, there is even a harness that allows you sub control via RCA's
Bestkits - BHA5700R
are you useing a aftermarket wireharness?? rem. turn on not hooked up????
try to see if you can get the spkr's to pop with a 9v batt. if they dont pop at all (all 4) there's more then likley a factory amp that need's to be powerd up.
there is no "amp plug" perse, could be amped without the sub, you can try the speaker pop method suggested above, I would only use a 9 volt battery though. Take the plus and minus of the speaker leads and put them to the plus and minus of the 9 volt and expect to hear a pop - no pop, then there is an amp - or the speaker is really ****ed.
this guy is an installer iirc.. .. and Should know what to do...
Grounded out speaker or speaker wire? I've seen a few of those have amps in them, but mainly they have the factory Pioneer system with the Factory sub behind the back seat on the driver side.
starkfu
starkfu
Hartland, WI
crx4luke
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
