focal solid 4 black $225 shipped no trades
dbeez
focal solid 4 black
used missing one powr set screw and one speaker set screw
Technical specifications
High-pass filter
50 - 150Hz (12dB/oct)
Low-pass filter
Remote control
yes
Maximum cross section of speaker wires
10mm2 7 AWG
Fuse(s)
2 x 25A
Nominal power measured at 14.4V continuously into 4 Ohms THD + N
4 x 75W
Input impedance
20 kOhms
Damping factor @ 4 Ohms
50 to 1kHz
Signal/Noise ratio (RMS)
>100dB (A)
Frequency response
10Hz - 60kHz
Input sensitivity
0.2 - 5V
Maximum cross section of power cables
35mm2 - 2 AWG
Protections
- Short circuit - Thermal overload - Overvoltage - Polarity reversal
Dimensions (HxWxD)
13/4 x 1113/16 x 77/8" (45x300x200 mm)
Signal/Noise ratio (1 Watt output)
>80dB (A)
Nominal power measured at 14.4V continuously into 2 Ohms THD + N
4 x 100W
THD + N @ 4Ohms
0.02% @ 1kHz
Power in bridged mode measured at 14.4V continuously into 4 Ohms THD + N
$225 shipped conus
included in the conus
Everybody who knows anything about quality, know there is a reason the price on this amp isnt the lowest, not only that but Focal Audio is a high end brand. Def. worth the asking price guys..you will not be disappointed with this amp
dbeez
dbeez
crestwood,ky
dbeez
