Focal KX27 11" Sub
ace_800
Excellent condition 9/10 due to bottom of motor being slightly scuffed/scratched. 10/10 mechanical. This is a pure SQ sub and one of the best out there. Sub was only used for about 6 months and I picked it up today. Beautiful sounding sub. Sealed box volume: 0.71-1.41 cubic feet
Nom. power 300 W
Maximum power 600 W
Sensitivity 88 dB
Cone K2 Composite Sandwich®
Surround Butyl
Nom. impedance 4 ohms
DC resistance 4.6 ohms
VC diameter 65 mm 2.55 in
VC height 26 mm 1.02 in
Former Kapton®
Layers 1
Wire Flat Copper
Inductance 1.9 mH
Xmax 9 mm 0.35 in
Magnet d x h (12) 60 x 14 mm 2.36 x 0.55 in
Magnet weight 2106 g 4.66 Ib
Flux density 0.9 T
Gap height 8 mm 0.3 in
Net weight 7.2 kg 15.87
Fs 48 Hz
Vas 14.92 I 0.53 Ft3
Qts 0.908
Qes 0.97
Qms 14.19
Re 4.6 ohms
Sd 314.16 cm2 48.7 in2
Cas 1.06E-07 m5/N
Mas 102.23 kg/m4
Ras 2186.43 ohms.ac
Cms 1.08E-04 m/N
Mms 100.9 g 0.22 Ib
Rms 2158 g/s
Ces 694.84 mF
Les 15.63 mH
Res 67.29 ohms
BI 12.05 N/A
SPL 84.23 dB/W/m
450obo
Will trade for 2/4 channel MMAT that does 100+/channel and Mono/bridgable MMAT that does 2k+ @1 ohm or something of similar quality and size
Included
ace_800
ace_800
Okinawa, Japan
ace_800
