Foam on my Speakers keep tearing
nehal1802
Basically I use a MEX-XB100BT Head Unit with front JBL GTO608C speakers and rear Pioneers (I forgot the model). About 4 months in I had to replace one speaker due to the rubber cracking. 6 months later the same speaker started to tear and the other one is pretty much completely torn. It's a pretty straight cut (see pic below) and I know the door panel isn't hitting it.
Any ideas what could be going wrong? I'm kinda new to car audio, I know how to install it but that's about it.
https://photos.app.goo.gl/gZum99XiRiPIKSuz2
going over mechanical limits will separate a cone from a basket, clipping will fry a coil, quit parroting everyone's default clipping reason for every issue.
Are you tossing that comment my way? Because your answer is not much different from mine minus the clipping, and I don't parrot anyone.
There's a parrot on one of the routes I do (I'm a mailman) and it says "**** you" to me every time I go by the house...
That's awesome !
OP, in addition to previous recommended causes...be sure the baskets are not in a bind as you tighten them to the panel. Square/flat mounting with even pressure is a necessity.
LOL a reasonable question is asked and within a couple of posts the old biddies brigade show up and start chirping at each other. I often have to check to make sure I'm on the Car Audio Forum instead of the gollywood b ithches c unt f art at each other site...
aka Thunderdome?!
Mineral wool is another nice dammned good insulation fire proof. Prob same as the Rock wool mentioned. that stuff will last forever
14
Things happen. It will be a story you can tell him and laugh about when he gets older. Kids around speakers = damaged speakers. I had a yard...
106
411
nehal1802
nehal1802
Malvern, PA
Greengecko
    Apr 28, 2024
    Apr 28, 2024
