First time term lab experience
It's whatever it is. It might work it might not. I'm sure you have a ton of time on the meter.
Im sure after the scion you became a audio genius no?
Look at this dude continue to try to be somebody hahahaha
On a side note there is a 6db loss from 41hz to 30hz. I was hoping for a flatter response but when I built the box I didn't use any software to calculate a proper response curve so I'm guessing my box is the problem there as this is supposed to be a low end oriented woofer.
Yeah that's bad. Real bad. Software will only get you so far, it has no idea what the cabin gain is going to do. You've started the trail and error phase.
So I'm assuming cabin gain having a trunk car is what is causing my terrible peaks and loss of lows? How do I start to overcome it
valleyrider
valleyrider
Fresno, CA
B-Sh0t
