finished test
Originally posted by v8s10 the L7 werent put in the EXACT same box.. so it couldnt be ENTIRELY fair without destroying a few friend's boxes.
it was used in a 2.5 cube and a 3.5 cube.. boxes i had discovered over time were PRECISELY what the sub called for... as for the xxx, it was put in gereralized "perfect" boxes for various subs, to test it in all conditions.. a huge air space high tune ported, a average space with 2 different tunings, and a tight space with average tuning.. so it tested it on all levels.
to be quite honest i think that the xxx isnt all its cracked up to be. the difference between the dd 9915 and the xxx were astronomical. xxx did however sound a significant amount better than the dd when hitting those numbers, so thats the trade off.
numbers dont lie man.
would u say that the xxx was the best sounding sub there?
i fin it hard to believe it beat the xxx at all, you seem a little biased toward the kicker..
Originally posted by burtonsnow83 would u say that the xxx was the best sounding sub there?
you know, i'd have to say yes. of all the subs we tested that sub sounded the "best" as it may be.
in the 5 cubes it sounded like ***.. but what can you do..
in the 3.5's it sounded GREAT. i mean.. WOW.. its not s.q. sub but was impressive.
Originally posted by dave_3148 i fin it hard to believe it beat the xxx at all, you seem a little biased toward the kicker..
again champ..
look at the numbers.
not even going to make a debate about it. its stupid. i hate kids with more pride than brains. L7 kicked its *** in spl. sorry, it did. maybe a different box than what i offered would provide a better setup.. maybe it could hang.. i seem biased towards the kicker because i've gone through about 10 subs finding my db drag setup until i found this little bohemoth. its tried and true for me. xxx's arent as impressive for pure spl. look at my previous post. it was hands down the best sounding sub hitting 150s.. no doubt. the hc in my opinion sounded better.. but maybe just cuz it wasnt making our heads bleed. *(my friend actually got a nosebleed from the dd...)* and i tested the hc first... cuz i knew it wasnt going to be a baller. get off your high horse.
im looking into some 9915s though.. haha.
and on another note.. a 152 is a respectable number from a single 15. i mean **** respectable. especially for using boxes not even designed for it.
you forgot to mention that the XXX was the only woofer whose wiring included a series circuit, which in my testings, can show a moderate drop in SPL due to differences in the coil's wire (read resistance / impedence wise)... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you also didn't mention that the standing DCR of a series / parallel circuit on a XXX sits at 1.17 ohm, which is a bit higher than the other woofers in the test, and will lead to a higher in box impedence spike at test frequency.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
good test though.. always fun to see how they stack up.
Loyd L.
Originally posted by v8s10 re hc 15
results in sonoma:
box 1: 143.1
box 2: 144.7
box 3: 142.4
box 4: 142.8
results in ford: DID NOT TEST.. too much power.
box 1:
box 2:
box 3:
box 4:
results in envoy:
box 1: 143.4
box 2: 144.4
box 3: 140.9
box 4: 142.8
Great numbers. My box was tuned to 47hz. I just need at least 400 more watts to feed to it. I'm sure I can get 145, maybe 150 once I apply the dampening material and get a better amp.
read the numbers..
my crossfire benched 1270 at 1 ohm.
the kicker does about the same,
and my us amps does about 4k watts.. only burped off that.
xxx sounded the best when getting that loud, but the L7 clearly took it. if i were going to buy a new daily driver, it would most definately be the xxx based on this test.
start going to comps, and have a best friend who owns the local audio store.
oh.. and make sure all your friends have the best amps and subs on the market.
thats what i did.
v8s10
v8s10
far away
v8s10
