Finding replacement tweeters for Boston Pro60
lilgrasshopper
4
okc
I bought a set of Boston Pro60 but they're missing tweeters. Now I hear that the tweeters on these babies are bright. i dont like too bright...it hurts my ears. What do you recommend me doing? Whatever I get, it'll be mounted in the 4" hole on my Mini Cooper. Thanks in advance.
You could get some seas Aluminum 27's
http://www.madisound.com/catalog/product_info.php?cPath=45_229_250&products_id=633
or fabric 27's
http://www.madisound.com/catalog/product_info.php?cPath=45_229_324&products_id=1466
With 4" you could go with large frame tweeters like the Vifa X25 as long as
the location is not likely to get the speaker touched or bumped, otherwise you need
one with a grill solution.
http://www.madisound.com/catalog/product_info.php?cPath=45_229_427&products_id=1181
There are lots of good tweeters on madisound, just make sure you do a little
research on the ones you like. Another option is to go active, I heard the BA's come
to life and cut the harshness when you do.
I have a pair of Pro60s. With the tweeter x-overs set to -2, they're not overly bright in the least.
$11.00 - what did you expect?
Hope you get it figured out! What crossover point are you using? Or are you trying to use them on the passive x-overs that came with your bostons? If i recall correctly, the bostons are 3 ohm drivers, so putting a 4 ohm driver on their crossover will result in different x-over point than you would have with boston's tweets.
lilgrasshopper
lilgrasshopper
okc
headless
