finally got the alty installed *pic*
SPL140.2
Team DefJ
at last the alty and the second run of 1/0 guage installed had to make a bracket to hold the fuse holders though. But it turned out ok. Have 3 inline fuse holders can only see 2 the third is under the plastic bracket. I wanted the 2 runs going to the back directly connected to the alty but there was no room for mounting the fuse holders plus its really tight in the engine capartment.
Egg
had a small problem today, a little smoke a little spark but its ok now. the wire tie somehow broke and one of the 1/0 guage wire touched the manifold heat guard and well you guys now what happens i guess this is what i get for using cheap wire ties. stuck like 10 wire ties on them now and fixed the wire. lol
your wires are running real close to your engine block on the back better hope it doesnt get to hot n start to melt the plastic and ground it self of your block
actually there 5 inches away when tied down to the ac hose, but also put some aluminum tape for hvac installs so it should be ok //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
SPL140.2
Team DefJ
SPL140.2
NY
2loud4u
