fiberglassing inside of boxes
I glassed the box on the inside for my RE XXX 15d2. It helped me get a little better airflow and i have a lot of bracing so I dunno if the flex was a problem before. But it does help seal the box. and it did make a little difference in the sq
thanks for all the input. i did consider doing a brace. how about a double baffle? ive never double baffled the front of a box. is it worth it or does it make more sense to just do some cross bracing?
ive read it alot too i just wanted another opinion. ill prob go with both the bracing and fiberglass that bish
mdf is not solid, air will pass thru it, bracing and a coat of resin is the best way to go.
A... air will pass through it cause its not solid?? WTF you talkin about??
B. Resin will not add any kind of bracing to the box.. might act as a filler like caulk or glue or bondo
C. MDF is not solid?? wtf you talkin about
D. FIBERGLASSING the entire inside might help a little bit... but thats dam expensive for the POSSIBLE result.
E. Fiberglass gains its strength with curves and turns... you've never seen a whole SQAURE or RECTANGLE box made outta fiberglass... Most boxes with fiberglass have the base of the box made with MDF, and then just the top (which is usually curved or rounded somewhat for the cosmetic appeal) is made with fiberglass
F... so, did you fiberglass the whole inside, or just cover it in resin
G.. MDF is not solid and air will pass through it... WTF??
no glass just the resin? the glass shouldnt hurt and only add structural integrety id think
phemps
phemps
PA
snb778
