fi vs. mojo's
im upgrading my subs again loli went from 2 mojo 15's
to 6 type r 12's
now im thinking of 2 15 fi's
im just curious how do they compare to my old mojo's
ive never been able to hear any fi's in person cause idk anyone in st. louis with them
i would think going from the 6 type r 12's to 2 15" fi's is a downgrade. haha...i have nooo idea what kind of power you were running or what kind of box you had them in but if you you have the power and space those things would be way louder than the 15's
like i said though im pretty well set on upgrading again
mybe 4 15's igf i can fit em
200 amp alt big 3 2 batts in back
0 gauge wire through
how many runs of 0 gauge? for a system pushing that many watts rms and haveing 2 extra batteries in the back you would need AT LEAST 2 runs of power to the back batteries... Im 100% sure the 12's would be louder than the 2 15's.... 4 15's would probably be ok. the 12's will have 678 sq in of surface area and the 4 15's have 706 sq in... so if you get 15's get 4 good ones .other wise keep the 12's and build a better box than the one you have.. if at all possible. do a subs up port back and do aeroports.. or just build a real wall with more port area than the ones you got now.
im pretty sure all my eletrical is up to par
as i can idle full blast w/o dropping enough to notice
im not big on building a wall either
and that is the second box ive ever personally built
built it all to spec with what alpine says
then after i built it i learned there r better ways to build it
but atm im burping at what i would like music to play at lol
your not going to come close to mid 50's on that power ,,sorry assuming 55 is what you ment. with a well built wall yes but i would be shocked if you could do it on 4-5k
treadburner
treadburner
st louis, mo
Lakota
