Fi SSD
when you say better are u asking if it will be louder? honestly if you want to get louder, with useing the same amp u have why not port the CVRs assuming they are sealed?
ohhh then i win! i will need to aero my box now then. i only have 3 cubes after displacement though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i was thinking using a 5 inch aero tuned to 35 hz?
if you can find a 5" aero let me know! just build a new box, not that tough
It'd take time and patience but you could cut rings of MDF and keep stacking and glueing them together untill you have the right length...and you could even flare it on both ends by slightly changing the diameter of the rings when you come to the ends and then rounding over+sanding them smooth...//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif..that'd be the way to do it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif (that way you can do any diameter you need //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif )
(And as you glue every couple rings together you could sand the insides smooth or even get body filler and make the insides perfectly smooth, just a couple rings at a time so you could reach the part you were wanting to body-filler and sand //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif)
i was gonna get 5 inch pvc pipe and cut it to the right length //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
PVC is not the same thing as an aero port. Aero ports are flared at both ends which reduces turbulence and allows for less port area than a standard round port. 19in^2 of port without a flare is just not enough for those two 12s.
j_alexander
j_alexander
Tukee, AZ
mattldm
