Fi SSD for SQL (LOUD)
i think mmatts dude and the op should have a little meet so the op gets a general idea of what the ssd's can do performance wise
Im feeding them 750 wrms a piece so think he wont be hearing full potential out of them, wish i had 1000 or a little bit more on each:crap:
its on the small side, they like about 1 - 1.6 cubes per sub. if you need help i only live 45 min away...
also if you stuff some polly fill in your box that could help, 1.5 lbs of fill per cubic foot will get you about a 30% increase...
Do you own, Fi SSD subs? id like to listen to them if you don't mind.
the fact that my box will only be able to provide 1.0 per sub will i have issues with the output i will get?
If your subs call for something bigger then 1.0 cu ft, then yes it will effect the sub. You can give the sub more power, but you'll lose efficiency. Which is why you see the spl comp cars with one 12 or 15 in a tiny *** box. If you build bigger you'll have opposite effects. The power handling reduces, and the sub can bottom out easier, but efficiency improves. If you build your box, don't make it too much smaller than called for, cause efficiency will go down, and if your system is daily, efficiency is much needed.
Cali_Screw
Cali_Screw
Rancho,CA
denim
Mike Mccabe
