no one said that subs don't break in, I said that FI subs spiders are soft enough to be safe used right out of the gate.
They can be used, but I wouldn't go full RMS on ANY speaker right out of the gate.....no matter how "soft" the spider is. That isn't the point, the resin in the spider and the triple joint stress is the point.
At the bottom of the first article, Dan Wiggins of Adire Audio wrote:
"The biggest reason there is a break-in period for drivers is the spider. The spider - for those who don't know - is a piece of cloth, permanent pressed, and dipped in epoxy. When you break in a driver, you introduce micro-cracks throughout the epoxy, which will make the spider softer.
ALL mechanical systems will wear and all mechanical springs will get softer; in this case, it's by design. You break/crack a lot of the epoxy bonds (phenolics are used as well) that permeate the spider, and thus it becomes softer.
We often see a 20% drop in Fs over a lengthy break-in, and we quote numbers for drivers broken in. Out of the box all our drivers measure high; beat on them for 40-50 hours, though, and they will be permanently lowered (Fs, that is)."
There is a lot more to that article, along with another response from Credence Speakers "...consistent with THOUSANDS of measurements I have done. Anyone who thinks a woofer's parameters don't change due to break-in / burn-in is either ignoring the data, has lousy data, or is not doing much of a break-in. ".
