Fi SP4 D-1 question
noname
For the SP4 D -1 owners who have used this driver wired in series on an amp that is stable only down to 2ohms-
Have you ran into problems with shutdowns etc.... or has the setup worked OK while being maxed?
Also if you could add what type of box it was in - sealed or ported.
Nothing more than what I ask in my OP. The only additional question I would add is what type and size of box was being used. I will edit my first post.
What's your electrical? Sounds like amp is heating up and going into protect for a few seconds. But you didn't tell us much so it could be many things.
I don't want to derail this thread - with that said I will give a little insight.
These are being using in a home setup with pro audio amps. Everything is done 'right' for the situation at hand.
I'm pretty sure the driver/enclosure combo is sending the amp a decent impedance dip causing it to hit protect mode for a couple seconds. It's not heat related. Most nominal 2 ohm drivers should not be dipping so low it causes a problem for a *solid* rated 2 ohm stable amplifier, but of course there are exceptions with drivers.
Also to add is the DCR of the SP4 is a bit lower than the other drivers I've had on the system, or plotted in winisd.
The SP4 18 plots lower than a few other drivers I have in winisd when viewing the impedance chart. With that said there are so many variables it's impossible to hang the hat on a winisd plot.
So- hopefully that cures the curiosity and we can continue to share experiences of d-1 sp4s being wired in series and hammered on amps that are only stable down to 2 ohms. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Mine was in 4cf tuned to 30hz. It slammed
I do have another question(s) for you. What size was your driver, and what type of ported enclosure was it? I'm curious see what winisd puts the impedance at with your configuration.
I would be glad to help you more just like anyone else on this forum but your question is kinda vague. If you have a good working amp on a solid electrical and gains set correctly you shouldnt have a problem with (shutsdown/Protection mode). But none of us here know what you have because you havent went into further detail about your problem
Thank you. I really don't need help with my problem, I'm just curious if others are having issues with their SP4 18 d-1s running at an amps rated minimum ohm load.
In the next couple days I'll be plotting an impedance chart of my setup. Just gotta find the time.
noname
noname
oregon
noname
Mike Mccabe
