Fi Q q12" Questions...
basilray
I'm looking at getting a 12" Fi Q w/ the BP upgrade and Dual 2 so I can wire it to 1ohm. Thinking of running it sealed. Can I safely run 1200w to it?
I was looking at a HiFonics BXi 1210D to run it.
Also, I know I should do the Big 3 if I'm going to be running anything, but could the big 3 wait until spring even if I put in the amp now? I'm in Minnesota, so getting warm enough weather to do anything is always tough, especially since I don't have a garage.
It will be going in a 2005 Mercury Mariner.
Or does someone else have a better suggestion on the sub or the amp? I'm looking for more tight and accurate bass.
So the consensus is that I should be OK running 1200 watts to a sealed Fi Q built to spec w/o immediately upgrading the Big 3?
I took peek under the hood and couldn't even find the alternator!
The best thing about GM Vehichles is that the alternators are always right on top of the engine! Leave it to me to go to Ford.
So the consensus is that I should be OK running 1200 watts to a sealed Fi Q built to spec w/o immediately upgrading the Big 3?I took peek under the hood and couldn't even find the alternator!
well if ur going with the hifonics, u will need to do a big 3;)
I was mainly thinking HiFonics because I wanted to save a few $$$
I'm looking at the AudioQue 1200D that was suggested, and it's not much more expensive.
How much would a Cap help me? Would that help me to go with either amp without doing an immediate Big 3 upgrade? I've never run one before.
it wont, its just a waste of money.
Uh, I drive a Ford, and my Alt is right where it should be, on top //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ive seen non BP Qs handle that power easily, but I would suggest you do the Big 3, can only help once the amp is in there.
I had 2 18" Q's without BP and they took 3000rms just fine, i would imagine with BP a Q could take 2000rms clean in the right box.
From everything I've ever heard...I would believe that. I just don't need to push that much power. Not trying to impress anyone, just want to add some nice, clean, tight bass.
1200 should be fine. the big three can wait.
also, i must admit the Q in a sealed box doesnt sound much better than my previous setups with more wattage and ported boxes. meh, it works tho.
There's a decent deal for a 15" in the classifieds here. Will that give me as tight of a response as a 12"? I'm looking for an answer from someone who's run both the Fi Q 12 and 15.
That, or I could probably finagle getting 2 JL 10w6-v2's from the classifieds. Or maybe 1 12-w7.
I hate options!
That myth about larger woofers not playing as fast or "tight" as smaller woofers is getting pretty old now.
I would go for the Q myself.
indeed it is, and it has already been pretty old.
a Fi Q with BP power added should be able to take 200-500rms more than the 1000rms rating, in the words of Fi, so that sub will take 1200rms just fine, and could deff put more on it with proper install, box and tuning. and as far as electrical you should be ok for a couple months or so, i was runnin 1000rms in a '00 camry with no upgrades, but a yellow top or some kind of dry cell, like a kinetics, wouldnt be a bad idea.
basilray
basilray
MPLS, MN
altoncustomtech
slater
    Oct 4, 2025
    Oct 4, 2025
