Fi Q 18
Fique
Hello all i'm new, I am in the process of upgrading. Got the first sub and amp going. Heres the thing, I cant stop the thing from bottoming out. I know the amp is too much but is it really that much too much? I was running at 1 ohm. I had the gain at ZERO boost at Zero ssf at 20-30. Seems like this sub should handle this amp with ease.
I had it hooked up to a jl 500/1 and it sounded very close to the soundstream
maybe even more sq.
Since I have hooked it up at 4ohm and I am able to get 75% gain but my ssf is so high I have no low hz. The jl was just rumble this thing.
I dont get it.
Specs ;
-soundstream trx2000d
- Fi Q 18 bp upgrade
-Sealed 6 cube box
-Factory Alpine hu w/6 disc
The amop is a turantual 2000watts @ 1ohm, 1100@4ohm. The bp upgrade puts subs rms at 1300-1500 watts, underrated i was assuming. Sorry if this is in wrong topic.
if the amp is rated 2000@1 ohm then thta is way to much for the sub. that 1100@4 ohms should be good. and the soundstream tarantula is a AMAZING amp. a guy at a audio shop said that they compared jls best amp to a tarantula and the jl was clipping and overheating it was just no match:)
First things first.
You can safely turn your subsonic filter either off or all the way down. You are running a sealed box so there is not much danger in damaging the woofer without it.
Also what is your LPF set at?
And as mentioned 2000 watts is to much for a Q. They do well in my experience on 500-1200 watts sealed.
I know but jeesh..youre gunna put 6 cubes in your car...sealed? might as well port it and have a lot more output.
Also if your shit is bottoming out on ZERO gain...somethings very wrong
my friend has an 18" FI Q on 1500 rms with no options at all and it handles it fine, no bottoming out on like 1/2 - 3/4 gain...
so one with the BP option it should be just about in the same boat as my friend
Fique
Fique
michigan
Fique
