Fi btl 15 ???
SO much fail in this thread. Everyone that says "it will take x amount of watts to get y sub moving" is not properly informed. Simply do not listen to them.
then do us all a favor and properly inform us instead of comin outta nowhere with your ragepants on
I'm sure you thought that was very clever, yet I didn't "rage" on anyone. It would be much easier for me to explain why you're wrong when you explain to me why he needs 2500+ watts to "get a btl moving".
that's what i asked the first time. if it is much easier for you to explain it then why didnt you just do so?
btl will get loud off of 1000w. it will get louder off 3000
just about any set of 4 12's will get louder though. you're talking more than twice the cone area, so even at 300w a sub that will be over 1000w and over 2x the cone area and more motor force as well.
I'm not saying I agree or disagree. I'm just saying it's not quite that simple.
Answer some questions and you'll understand why you're so wrong.
#1, across the sub bass frequencies (20hz - 80hz), if given the same amount of power does the woofer travel the same distance?
#2, When taking into account port tuning frequency, does the cone move the same distance on the same power above tuning, at tuning, and below tuning?
#3, Does the distance the cone travels directly relate to SPL?
These questions should get us started pretty well.
valid points, has nothing at all to do with the question at hand but valid points.
a woofer with more power will move more air at all frequencies and create more pressure. end of story.
Not relevant. It was stated that x amount of power was needed to "get the btl moving" and my questions are dead on point of showing how that is NOT true.
more power will move it more.
obviously 1 watt will get it to move, it's a figure of speech to say how much power will get it moving to where it will be performing optimally
It's not a figure of speech. That's a cop out. Admit you're wrong and stop making excuses for it. "optimally" wtf does that mean? Answer the questions above and it clearly proves you wrong. Answer them.
jesus christ you are dense.
all i'm saying is more power is better for a subwoofer up until its thermal and mechanical limits.
as you increase power you get more output...a simple test can prove this - turning up the volume
GAMEOVERCCA
INCRIMINATOR AUDIO
GAMEOVERCCA
Hickory NC
LosIsATool
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
