Few questions on Wire/Wiring
da_bOm
Aight boyz (n gals) iam in need of some help here, I have a JBL BP1200.1 for my 2 12' Type R's, i got a few questions for y'all. First off is there a noticiable difference is speaker wire, like from this plain jane wire or say a lighting audio wire?. Next iam trying to decide what size wire to run to my amp from the battery, should i go 8 or 4? will 4 be that much better? but iam then if i go 4gauge concerned about a fire hazard (rather not have my ride go up into flames!) any help would be most appreciated
If you're gonna be running a JBL 1200, you'll want to use 4 gauge wire, 8 gauge is just too small. As for using brand name wiring, some people say that the more expensive stuff works better because of better insulation and all but for the most part, as long as you use Oxygen free copper wire, you'll be ok...I use all Stinger, but i guess its all about personal preference.
Keep it loud!
JELLYDIME
Jellydime is right. The only thing that I will add is the cheaper wire tends to corrode rather quickly. Cheaper wire generaly has a smaller strand count which limits flexability and could restrict the signal transfer.
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
511
da_bOm
da_bOm
British Columbia
natem33
