us amps us-x3 3 way active xover, cosmetically flawless.
powers up, works fine. has a plexiglass top so you can see all the internals..
http://www.usamps.com/old_site/products/inv/us-x3.htm
` Three-Way Active Electronic Crossover
` Four Channel Input with Six Channel Output
` Selectable Three-Way or Two-Way Operation
` Nine Volt Outputs with Separate Gain Controls
` 50Hz-500Hz Variable Low-Pass Output
` Variable Mid Range Output with 50Hz-500Hz High-Pass and 500Hz-5KHz Low-Pass
` 500Hz-5KHz Variable High-Pass Output
` Mid Range Phase Inversion Switch
` Delayed Amplifier Turn-On Output
` Fuse Rating: 3 Amps
` Dimensions: (Including Terminals)
32mm / 1.25in High
241mm / 9.5in Wide
165mm / 6.5in Deep
` Weight: 0.91kg / 2.0lb
` MSRP: $379 USD
just offer for it, ill tell you if its near what im looking for. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif - i wont bash anyone or get pissed for lowball just inform you it might be a little low
32mm / 1.25in High
241mm / 9.5in Wide
165mm / 6.5in Deep
` MSRP: $379 USD
