Sold Feeler... two 12" custom-built TC Sounds 3hp motor subwoofers
Wingman0121
Just seeing if anyone's interested... rebuilt by Robot Underground, these were Eclipse 9122s with quick change assembly(so the basket can unscrew from the magnet without ripping the cone off) except now it has a honeycomb cone, tall rubber surround, dual 2 ohm voice coil and 180mm dustcap. I was told that these are very close in spec to the Audiopulse Axis. Can easily take 1000 RMS a piece, currently it gets power from an Audiopipe AP30001D. Looking for $270 shipped each or $500 shipped for both within the 48 states. Would rather do a local sale because of weight. No trades.
REVO uses a TC9 with two 1" slugs and a shorting ring under a SHORT top plate. These use the 3HP with three .75" slugs and no shorting ring under a TALL top plate. AXIS uses a 3HP with three .75" slugs and a shorting ring under a TALL top plate. It would likely spec closer to a Lightning Audio Storm than an AXIS due to the thicker rubber surround and higher inductance, but it's certainly not like a REVO.
thats a 3 slug tc9 motor, its not a 3hp
Robot Underground makes horrible products. its a local store and from what i hear and have researched is a horrible company. do your research before you buy. not telling you not to buy. but just do your research.
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
audiobahnfan
