Sold Feeler... two 12" custom-built TC Sounds 3hp motor subwoofers
Wingman0121
Just seeing if anyone's interested... rebuilt by Robot Underground, these were Eclipse 9122s with quick change assembly(so the basket can unscrew from the magnet without ripping the cone off) except now it has a honeycomb cone, tall rubber surround, dual 2 ohm voice coil and 180mm dustcap. I was told that these are very close in spec to the Audiopulse Axis. Can easily take 1000 RMS a piece, currently it gets power from an Audiopipe AP30001D. Looking for $270 shipped each or $500 shipped for both within the 48 states. Would rather do a local sale because of weight. No trades.
its close to a revo not an axis and check ur price they have those on ebay for cheaper from robot underground
REVO uses a TC9 with two 1" slugs and a shorting ring under a SHORT top plate. These use the 3HP with three .75" slugs and no shorting ring under a TALL top plate. AXIS uses a 3HP with three .75" slugs and a shorting ring under a TALL top plate. It would likely spec closer to a Lightning Audio Storm than an AXIS due to the thicker rubber surround and higher inductance, but it's certainly not like a REVO.
You interested in a ED 13 av.2 D4? I have a similar sub that was built off the LA Storm motor and built by robot underground to be close to the TC sounds Axis. Hell of a woofer.
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
audiobahnfan
