modding lowers the impedance it can handle....which makes more powermodding doesn't increase power simply turns off electronicly controled protect(i think)
ok...unless it is a regulated power supply then yes it will...which is why this is modded...to make it stable at a lower ohm which...makes more power.once again modding doesn't increase power...
Because it could possibly viod warranty, might heat up faster.then why didn't ma do it at the factory???
x2. Modding an amp is to lower the ohms= producing more watts.ok...unless it is a regulated power supply then yes it will...which is why this is modded...to make it stable at a lower ohm which...makes more power.
modding an amp is to lower the ohms? what are you talking about?? modding inables the amp to go to lower ohms without going in protect not make more powerx2. Modding an amp is to lower the ohms= producing more watts.
