Feel free to rate my setup
that w7 probably sounds like a w3 because your amp isnt strong enough. The bigger the woofer, the more amp it takes to push it. I would get a 3000 watt amp at least. I tryed to push my alpine type rs with a 1000 watt ap before and it didn't even flex them. But i would give your system like a 6 out of 10 or something. Infinity is good for its price and the w7 will kick *** if you got the right amp. NOT BAD IMO. I wish i could afford a w7.
Are you serious? You're recommending 3000W AT LEAST?? Wow....
wow
op, sell the rears and put the money towards better fronts
W7 = 1000/1 v2 plain and simple but the 1000/1 at i thin 16 volts put nearly 3k watts out its a beast of an amp. but at normal 14 its about 1200 which is perfect for an efficient power supply for the W7
The JL 1000/1 is all you will need to push that W7 efficiently! Clean up your front and rears and you'll be a happy camper, although I am sure you already are.
Good advice, if you want a loud settup.
Send the dub 7 3KW rms
Blow it
Catch car on fire
Get new car
Buy new equip
...profit?
Not a bad beginner system at all, enjoy it!
You just said get a 3000w amp to power the w7
and now you said with a 1000w amp, you can't get 3k out of...
If you mean to have max watt in there somewhere i understand, but go read something about CA and get back to us
wat
He has me rethinking, things, im not sure im sending my setup enough power now:crap:
op. Not bad for a first. Probably better than a lot of people's first. You'll be happy. Just upgrade the front speakers and a little bit larger amp for that w7. Don't listen to the dipshit above. You don't need anywere close to 3kW to push that w7. Good luck to you and ask questions as you go along.
So with this amplifier, all you have to do is increase its input voltage 15%, and its output will increase 150%? Amazing.
I've always said that JL Audio uses stolen alien technology from Roswell. I know the W7 utilizes some of it as well.
916Kev
916Kev
Nor Cal
t-money
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
