Factory Alarms?
SirSteve
I just purchased a 2003 Toyota Tacoma (new system going into it) and it has a factory alarm that has these features:
SECURITY AND CONVENIENCE ALL AT THE TOUCH OF A BUTTON
- Vehicle Specific Design: VIP system is custom built specifically for your Toyota vehicle
- Point-of-Entry-Protection: Activates VIP's full alarm cycle if any door, trunk, or hatch is opened without the key
- Full Alarm Cycle: For 60 seconds the lights flash, horn sounds, starter is disabled, and the Forced Lock feature will continue to re-lock the doors(on models with electric locks)
- Starter Disable: Prevents the vehicle from being started after the alarm is triggered
- Hot-Wire Protection: Sounds the alarm and disables the starter if an attemt is made to start the vehicle without the key
- Automatic Arming: Insures that your VIP system will automatically arm after exiting your vehicle(when programmed)
- Rolling Code Technology: Helps protect your VIP system from code grabbers that can steal your security codes
- Glass Breakage Sensor: "Listens" for noise and triggers a 20 second Warm Away Alarm if it senses that the window glass is tappped or broken. Full alarm is triggered on the second detection
- Automatic Rearming: Allows VIP system to re-arm if no door or hatch is opened after remote disarming
- LED Display: Warns intruders that your vehicle is protected by VIP security
CONVENIENCE
- Remote Keyless Entry: Conveniently locks and un-locks doors
- Remote Arm/Disarm: Activates/deactivate VIP system via remote control
- Passive Disarming: Allows ignition key to disarm VIP security system after automatic arming
- Tail and Marker Lights Flash: Confirms successful arming or disarming
PERSONAL SAFTEY
- Panic Alarm Button: Remotely activates alarm to sound horn and flash exterior light
- Interior Light Activation: Turns on lights when the system is disarmed using the remote
- Door Ajar Warning: Sounds if a door is ajar when remotely arming the system
I really like the ideao of not having to add another alarm. What does everyone think of this alarm? Should I get an aftermarket one or keep this?
SirSteve
SirSteve
USA
96greencivic
