Facing subs > < sound differently?
i would think their would be cancelation by facing em to each other
Not any more likely than facing any direction, unless of course your trunk is 20' long. Bass frequencies are way to long to blanket it that way. It might be fine to shoot them that way, but it probably will sound better another way--read pointing rearward usually.
if you face them towards each other in a like polarity, then it will sound like poo because they will cancel each other out. What you have to do is reverse the polarity so that when one sub is in, the other is out.
only if you mean an isobaric type enclosure...then yes, you will be about 3 bd quiter, and need twice the power to regain these losses
That's not true.
Unless, like Polecat mentioned, you are referring to isobaric loading.
Otherwise..no, no need to reverse the polarity. You will want both subs wired in phase with each other.
im talking about if they are facing towards each other, where you would need the woofers in opposite polatiry so that the waves are not crashing into each other which causes cancellation. Which is what you would do in an isobaric enclosure.
The waves are not going to cancel each other out. As B&W pointed out...if you have one sub pressurizing the air, and the other sub decompressing the air...then you will have cancellation.
Wire both subs in the same polarity if they are facing each other on opposite sides of the trunk, like is being discussed. You want them compressing and decompressing the air together, not fighting each other.
Yes, you do that in an isobaric enclosure. Different situation being discussed here though.
gotcha.. lol i thought i was helping out, but it looks like im just making myself more confused.
this is when you would wire one out of phase. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ownage9
ownage9
detroit
Polecat
