F350 2004 Head Unit Question
Quick question, I will be replacing my factory head unit in the near future with an indash DVD player. I went to Crutchfield's web site and they only list single din units that have a motorized screen that flips out. I have seen many double din F350's aftermarket installs, but have not seen the bracket to use. I would prefer a double din unit. 2005 and newer uses a different bracket. I cannot see how it would mount for 2004 based on me taking apart the dash several times. Not sure which units if any would fit.
there is no kit u have to do it urself, pull the radio out with the din tools, then pull the dash off it just pops off after u undo 2 screws above the area behin the radio, u will have to trim/file down the dash to actually fit the dbl din, there will be a gap on the side to fill with a trim ring
with the dash off u should be able do drill 2 holes into the side and screw the radio in via that
medplus23
medplus23
Santa Clarita, Ca
pentavolvo
