Sold F/S TRU HAMMER nice clean old school
Louisiana_CRX
dem shoes......
This is a nice powerful clean subwoofer amp in very good condition.....These are very underated and rated at 2000 at 1 ohm...they will run daily at .5 ohm $650 shipped lower 48
**** i wish i had mine back...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i have sitting right next to me right now, what is probably the rarest piece of tru tech equipment that has ever existed //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Some Specs....
Description (revised)
Brand: Tru Technology RMS Wattage: 1500
Model: H-1 "The Hammer" Condition: Used
Channels: Mono (1- Channel)
Used, but like brand new, Tru Technology H-1 "The Hammer" Mobile Amplifier. Only hooked up to 1 sub for a very short time. Never abused. Performs and looks flawless.
SPECIFICATIONS:
Model: H-1
Channels: 1 CH
Frequency Response: 10Hz ~ 300KHz ±1dB
Rated Power: 14.4 Volts DC
T.H.D.:
4 Ohm RMS: 600W x 1
2 Ohm RMS: 1,000W x 1
1 Ohm RMS: 1,500W x 1
S/N Ratio: > 100dB
Input Sensitivity: 0.16mV ~ 4 Volts
Damping Factor: > 700
Efficiency: 69.10%
Fuse Requirement: 120 Amp
Power Supply: 11 ~ 17.9 Volts DC
Low Pass @ 18dB / oct: 40Hz ~ 300Hz
Sub-Sonic @ 24dB: 10Hz ~ 100Hz
Bass Boost: No
Dimensions: (L x W x H): 15" x 8 13/16" x 3 19/16"
Weight: 14 lbs. / 6.4 Kg
Very High Voltage/High Current Class AB Mono Block Bass Amplifier
- Absolute Sound Quality Performance with Tremendous Controlled SPL Output
- C & C Machined Heatsink with Hand Grinded Heatsink Fin Edges
- Constant Rated RMS Power Output until Thermal Shutdown
- High Voltage / Current Unregulated Bi-Polar Power Supply
- +/- 90 Volt Rail Voltage
- (10) ON® TO-3 (250 Volt) Metal Case Output Devices
- (12) I.R.® HEXFET® (60 Amp Rated) Power Inverters for Efficiency
- (2) Hand Wound Power Transformers
- (4) High Speed Rectifier Diodes
- (2) 100Volt 6800mf Capacitors
- (2) Pairs Complimentary Transistors for Input Stage
- (2) 3 inch Variable speed Intake/Exhaust Fans
- 69.1% Efficiency @ 4 W (Full Power)
- WIMA® Polyproplyne & Mylar Capacitors
- Balanced Line input capability
- Symmetrically mounted heat generating parts
- PROPRIETARY RF Grounding Techniques used for
Improved Reliability and HF noise rejection
- Power section uses Discrete Circuitry throughout Audio Path
- Linkable Amplifiers (H-1)
- 18dB Low Pass X-over (40Hz ~ 300Hz)
- 24dB Subsonic filter (10Hz ~ 100Hz)
- Remote Bass control knob
- 4 Gauge Power/Ground Input
- 8 Gauge Speaker Wire Output
- Hand Built in California, U.S.A.
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
