Like the title says //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
$150 shipped, lightly used
SOLD
PIONEER GM-6100F 4CH
CEA-2006 Compliant Amplifier Power Standard:
60 Watts x 4 @ 4 ohms
150 Watts x 2 @ 4 ohms BRIDGE
80 dBA Signal-to-Noise Ratio
Peak Music Power: 120W x 4 (4 ohm) / 300W x 2 (Bridge 4 ohm)
4 Channels
Continuous Power @ 4 Ohm: 60W x 4
Continuous Power @ 2 Ohm: 75W x 4
Continuous Power Bridged @ 4 Ohm: 150W x 2
Frequency Response: 10Hz-50kHz
THD (1kHz, 4 Ohm):
Signal to Noise Ratio: >95dB
Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
PWM Regulated MOSFET Power Supply
Balanced Isolator Input Circuit
Oversized Screw-Type Power/Ground Terminals
4 Channel RCA Inputs
RCA Outputs (Pass Thru)
Speaker Level Input
Screw-Type Speaker Terminals
Hi-Volt Input Level Control (200mV-6.5V)
Selectable Crossover (80Hz, -12dB/Oct.)
ref- ls2poweredgoat
SOLD
4 Channels
THD (1kHz, 4 Ohm):
Speaker Level Input
ref- ls2poweredgoat
