(2) Ol'skool ORION Amps in near mint condition. Both work great and include all plugs. These are the good ol' Made in the USA ORION amps before they cheapened their products and made them overseas. Serious car audiophiles will understand what I mean by this.
(1) Orion - Cobalt CO435 280 Watt 4-Channel Amp - $125. Will consider all offers.
(1) Orion - Cobalt CO465 520 Watt 4-Channel Amp - $175. Will consider all offers.
ORION Cobalt CO-465 Specifications (ORION Cobalt CO-435 Specifications similar but less power)
4 x 65W @ 4 ohms (0.001% THD)
2 x 65W & 1 x 160W @ 4 ohms (0.001% THD)
2 x 260W @ 4 Ohms (0.001% THD)
4 x 130W @ 2 Ohms (0.001% THD)
Power Bandwidth : 5-50,000 Hz (both channels drive, 4 ohms, 0.1% THD) Yes, 5 Hz.
Total Harmonic Distortion 0.001% (4 ohms, 1 kH, 75W)
Frequency Response : 5-50,0000 Hz +- 1 dB (with "Direct" input sensitivity controls at minimum), 50-50,000 Hz +- 1 dB (with "Low Cut" input, input sensitivity controls at minimum)
S/N Ratio : Better than 115 dB (HF A-TD, at rated power, input sensitivity controls at minimum)
Damping Factor : Greater than 1,000 (4 ohms, 1 kHz)
Input Sensitivity/Impedance : 0.2 - 0.8 V Variable / 50 kohms
Stereo Separation : 85 dB (4 ohms, 1 kHz)
Power Source : 14.4 V DC negative ground (10.8 - 15.6 V allowable)
Power Consumption (Max) : 27 A
(Music) : Approx. 10 A (4 ohms)
Load Impedance : Above 4 ohms[/b]
