SOLD F/S Memphis Mojo 16-MCD4KW Mono 4000w amplifier works great!
  • 6
ampjunkielikeme
nash, tn
525.00 firm .....shipped to the cont usa......no trades
i have 2 of these. the other one will be for sale in a couple days...its in mint condition and looks brand new. but its used , comes with the box, manual, mounting hardware...i want 650.00 shipped for it..
this amp comes with the box , manual.... good used condition. its got a scratch on the top, and a few scuffs here and there...it is not mint, but still looks very good.....it's missing the top cover for the side plates...and the bottom of the side plates has been shaved down a little for some reason..lol....it will have a bottom on the amp when you receive it..
had to fix the repair that memphis did....it had a bunch of nte parts that needed to be replaced because nte parts are JUNK!. had to insulate some wires on the transformer to fix the main problem it had.
i added solder to the legs of the power supply/output transistors to make the amp virtually vibration resistant ....
the amp is solid now , and is better than when it was fixed at memphis..(my honest opinion) ...it works 100% and will pound the crap out of your subs....
F.Y.I. -it says in the manual : electrical upgrades are mandatory to use this amplifier! example: high output alternator/multiple batteries.... a stock electrical will not be sufficient ....
so don't buy it, and blow it trying to run it on your stock alt and 1 battery, or even 2...it just wont do it.....just a fair warning..
Continuous power output
-4 ohm 1000wrms x 1 @ .5% thd
-2 ohm 2000wrms x 1 @ .75% thd
-1 ohm 4000wrms x 1 @ 1% thd
will run daily at 0.5 ohm
will burp below 0.25 ohm
Signal to noise ration: 95db
variable low pass: 50hz-250hz 18db/oct.
variable highpass subsonic: 20hz-50hz 18db/oct.
damping factor >50
Protection circuitry against overload, short circuit, thermal, and reverse polarity.
2 amps are strappable at 2 ohms for 8000rms.
Dimensions: 31.49" x7.6" x 2.4"
CEA-2006 compliant amplifier
Reliability: 8 - you've got to keep the voltage up, or the amp will go poof!
Performance: 10
Features: 9
Looks: 8.5
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.......
if anybody needs repairs done on their memphis 4kw amp (or any amp) , let me know....i do good work, and my rates are hard to beat...//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Pioneer SPL 12" you want for it, plus I will send you my 4k for repair for the $250 you quoted me.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you give me 100.00 and your spl 12 ..i will send you this amp......//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
send your amp to me...i will fix it for what i quoted you
sold to this guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:)//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
couldnt say no to this deal
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
ampjunkielikeme
ampjunkielikeme
nash, tn
BassAddictJ
