F/S MA Audio HK4000D
#guesswho?
Item(s) for Sale: MA Audio HK4000D
Up for sale is a good monoblock amp. It's used but still 100% functional. I purchased this amp from this site over 2 years ago. I used it to power an 18" Fi BTL for 2 months. My car alt was upgraded prior to the system being installed, so this amp has never seen below 14v. It was wired at 4 ohms. This amp never ran warm. It does have it's signs of wear, and the pics below show this. It's never been modded or repaired, 100% functional. I'm only selling it because I've moved onto a totally different system. This amp will do rated power. It's a really good budget amp that will put out some serious power. This is the perfect amp for someone looking to get lots of power while on a budget. I've seen others run this amp as high as 18v. It's a really good amp, I just don't have use for it at the moment. If anyone has any questions or comments, please feel free.
4000W Digital Class X Competition Mono Block Amplifier
RMS Power @ 14.4V
1800W x 1 @ 4 Ohm
3600W x 1 @ 2 Ohm
RMS Power @ 17.0V
2000W @ 4 Ohm
4000W @ 2 Ohm
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
Dimensions: 12.4 W x 2.71 H x 25.86 D
Price: $310 plus shipping. Please don't ask me "what's the lowest price shipped to..." because I don't play those kid games. If you have an offer, PM me.
TRADES: I will only consider trades for the following items:
- Sundown 100.4
- AudioControl LC8
- Sundown Neo Pro 6.5's
- Selenium ST350 or ST200
- Quality 6 Channel(has to be something good)
I will cover 50% of the shipping costs as long as it's within the lower 48 states. I will ship out via USPS the same day payment is received, as long as it's received before 4pm ET. Tracking number and insurance will be included. If you would prefer FedEx or UPS shipping instead, just let me know. Shipping costs will vary depending on zip code.
Might be interested if I can sell my new Kinetic HC16V 16 volt battery. Would you trade for it? It runs in 16 volt or 12 volt. I cant fit it in my teeny tiny Group 34 battery tray so I have to find an XS 3400D. I would probably need two of XS 3400D's to run this.
I heard they are power hungry. What kind of electrical were you running?
Sorry, I have no use for that battery being that I already have 4 matching batts. I have a HO alt in my car, so voltage was never an issue for me. As for being power hungry, I'd disagree. Their as power hungry as any other amp putting out a real 4k +. Any amp putting out over 4k better be power hungry.
If you're seriously interested once you acquire some cash, let me know.
#guesswho?
#guesswho?
the mitten
Flastrongman
