350.00 shipped to the cont usa..firm... .. no trades
this amp needs no introduction... it is a beast that can take just about anything you can throw at it..1ohm, .5ohm, .35 ohm . it can do it and be reliable..
it would be awsome for comps for the lower wattage classes. it comes alive when you load it down.. and you already know it is a great daily amp to begin with.
i had this amp repaired by chris at DB-r electronics. he is the authorized repair place for IA. he knows these amps inside and out... it has a clean bill of health, and is ready to rock and roll.....it comes with a 30 day warranty on the power supply...
the amp is known to put out 2400+ watts @ 1 ohm@ 14 volts . even more at .35ohm. but you must have the juice to feed it to get the power out of it..
ive read it will do very close to 3000 watts @ .5ohm...
cosmetics- i would give it a 9 out of a 10. it is in very good condition..
function- it works great!
specs are grossly underrated
version #1
1 x 450W @ 4 ohm
1 x 900W @ 2 ohm
1 x 1800W @ 1 ohm
S/N Ratio: 105dB
THD @ 4 ohm:
Efficiency @ 4 ohm: 86%
strappable to another 20.1 for double wattage..
version #1
1 x 450W @ 4 ohm
1 x 900W @ 2 ohm
1 x 1800W @ 1 ohm
S/N Ratio: 105dB
THD @ 4 ohm:
