Sold F/S Directed 1500d 1 ohm stable works great..cheap!..
ampjunkielikeme
130.00 shipped to the cont usa...no trades
ive got a directed 1500 watt amp that needs a new home, and i need some cash to buy one of my buddies a small amp,,,...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have not repaired this amp....it came to me working 100% i just dont need it.....
it has a few scratches and scuffs. i would give it a 7 out of a 10 for looks, 10 out of a 10 for function..
it is missing 3 of the speaker screws, but i have ordered 4 brand new ones that im waiting to be shipped to me...i also have a printed manual for it..
ive tested this amp out on my 12's for a few hours, and it puts out some serious power.....its very very efficient...and if you can find another 1500d , you can strap them for double the power...ive seen a few floating around on here....
specs:
Dynamic Power Rating: 1500 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 425 x 1
Rated Power @ 2 ohm: 800 x 1
Rated Power @ 1 ohm: 1200 x 1
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
*High speed MOSFET switching power
supply
*High current, high efficiency MOSFET
outputs
*Switchable 8 dB bass EQ
*180° phase invert switch
*Remote subwoofer level control function
*Thermal, DC offset, reverse polarity and
short circuit protection
gut pics!....its not a bad looking amp:eek:
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.......it has been tested , and works 100% ...
Same guts as the Hypnotic amplifiers that someone was selling on here.
Powerfull lil suckers.
/bump for you!
BTW Ampj did you get my PM about the Hollywood 4 channel?
yep, this amp is solid, and does it rated wattage......i like it alot....who ever buys it will like it to...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ampjunkielikeme
ampjunkielikeme
nash, tn
da box king
